59 Evinrude points setting help
earlybird
Have 59 Evinrude 4 cylinder with belt driven distributor, Model # V4SL-11, need to know how to set points, also where to buy parts, all help appreciated
JB
Re: 59 Evinrude points setting help
Howdy, Earlybird.<br /><br />My manual on the similar Johnson model says to set both sets of points at .020.<br /><br />You really need a manual to work on that ignition system. Try your local library.<br /><br />For parts that your Evinrude/Johnson dealer cannot supply, try Twin Cities Outboard in Minneapolis.<br /><br />Red sky at night. . .<br />JB :)
novacane
shouldnt need a manual to set the point gap at .020 no rocket sceintist stadis either good luck :rolleyes:
JB
Hi, Novacaine.<br /><br />I agree that setting the points is no problem, after you post for help.<br /><br />If you intend to work on your own engine, even if you have been wrenching for 50 years, you either need a manual or a brain transplant.<br /><br />Red sky at night. . .<br />JB :)
