59 evinrude 35hp
pdcauseway
i'm looking for some gaskets for the impeller housing,any idea where i can order them. I didn't see them on iboats store. thanks
F_R
Honorary Supreme Mariner
Re: 59 evinrude 35hp
If you really mean "gaskets", there is only one, part number 307955, used between the pump housing and water outlet that the tubes stick into. The water tube grommets are part number 305348. The big o-ring that goes on top of the pump housing is part number 202591. The o-ring that goes in the groove at the top end of the drive shaft is part number 303059. Get all that stuff from an Evinrude dealer.
