twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
My 18 Evinrude began overheating and I removed the thermostat which was stuck. She made it back to the dock after I took the thermostat out and appeared to run as she should. I went on to replace the impeller and after a number of tries in the barrel she still is overheating. I took the lower unit off and put it in a 5 gallon bucket and turned the shaft with a drill; she's pumping. I poured water into the (upside down motor) copper line that connects with the pump and water flowed through the power head and on out. I took the new thermostat out and ran it with the thermostat cover off and had water coming to the housing and spewing about. Water is pumping out the exhaust but it's very hot (especially considering there's no thermostat right now) and when in neutral nothing comes out the leg exhaust. Any ideas as to why she's overheating? thanks
