58 Sportwin
lightwin
Does anybody have the Napa part number or even a Sierra number for a lower unit seal kit for a 1958 Sportwin? Can't seem to keep the oil in the thing. I would like to get the kit rather than ordering the individual parts. How about the carb kit? Thanks!
nwcove
Re: 58 Sportwin
carb kit should be 18-7043 ( no float) seal kit should be 18-2679.......but plz check those numbers!!
lightwin
Re: 58 Sportwin
Thanks, I will check into those numbers. Is there a good site that will list the right numbers? I have found plenty of part diagrams but they never say the numbers for a full kit just the individual pieces. Also, are there any kits that include the bushing for the shift rod and the bearing housing seal or should I be looking for those independantly?
1946Zephyr
Re: 58 Sportwin
According to vintage outboard.com, the carb kit is number 18-7043 and the lower unit kit is number 22-26820
tin knocker
Re: 58 Sportwin
If that motor has been run very much with water in the LU you may have problems that a seal kit won't help. Make sure that the driveshaft bushing is not worn and also the driveshaft at that point. I've traveled that road.
