Big Jay
- Aug 7, 2012
- 256
Starting a new thread here guys... Hope that's Ok:redface:... lol
I've cleaned and reinstalled the carb on this engine replacing the packing washers only. The float was good and the float needle seems fine, doesn't stick and is not grooved so I kept it. The packing however, came out in pieces. I've cleaned and adjusted the points, and spark is jumping 1/4" on the tester. Compression is 118 and 120 cold and dry.
That said, I've had it out twice now. First time out, I had the needles at the recommended starting points and man was she rough. Took several pulls to start and coughed and coughed. Managed to get it to settle down only by turning out the slow-speed needle a good full turn to a turn and a half from the original 1.5 turns out. At 2.5 -3 turns out, she finally started sounding good. I then went to adjust the high-speed needle and at WOT she barely moved at all
. Once again I started turning out the valve to enrich the mix and after about the same amount of turning out it picked up and eventually I had it running like a champ. Once it was as good as it was gonna get, I re-adjusted the slow-speed and I was good. But not really.
I burned a quarter tank of gas in 15 minutes at WOT that day.
Upon inspection, the top plug was healthy looking, normal according to all charts online. The bottom plug however is black and sooty. This tells me (correct me if I'm wrong please) the top cylinder is likely the culprit as it is running right at this heavy-rich mixture, and the bottom one isn't burning everything and is sooty because of it.
In another thread someone suggested I was running "over lean" due to a possible air leak and my needle-valve positions were compensating, and this sounds about right to me.
I went out tonight intending to do the carb cleaner test, but chickened out because I just don't know lol. So I went for a ride instead. The motor did start nicely (kicked 3rd pull and started 4th) It still coughed a lot at first then leveled out a bit once warmed up, still coughing at idle, but livable. The fuel consumption however, I cannot live with.
My question is this:
If it's an air leak I'm looking for, how do I find it? Is there a procedure to follow, some things I shouldn't do? Someone suggested using a carb cleaner and spraying the gaskets on the powerhead a little at a time waiting between each squirt to listen for changes in RPM (intake manifold gasket etc.). My concern with this is if the gasket isn't the problem, am I going to eat it enough with the cleaner to create a new problem?
I appreciate any input on this as I am running out of daylight in the evenings for testing as the season rolls on by without me lol.
