Newbie here. Got water in the gearcase housing when I started the BigTwin I restored this winter. Rechecking everything and seems like I was supposed to seal the impeller housing? Shows no gaskets in the manual diagrams, so I am assuming I should have used sealer below impeller plate (where it sits on the gearcase housing) and on top of the impeller plate (where the impeller housing sits)? Can anyone confirm?
I am also planning on replacing the rubber bushing that seals the water tube where it fits into the impeller housing. How important is it to replace the shift rod o-ring and gasket that are located under the bushing in the bottom side of the gearcase housing? Not sure how I'd pull the bushing (looks to be brass) to get to the seal and o-ring.
Many thanks in advance for any help. Motor is mounted on a '59 MFG Celeron that I also restored and I'd like to get in the water this year!
Steve C.
Steve C.
