'58 Big Twin 35hp impeller plate & cowl badge
sccasey
In the middle of a rebuild and have a question about the impeller plate on my 58 Big Twin 35hp Electric Start. Is the slight depression or dent shown in the photos normal? Can see in foreground of top photo and far side of bottom photo. Looks "factory" in that the shape is very regular and even, but when I pulled the cover the impeller arms were all detached and I thought perhaps something got wedged under a rotating arm while the motor was running and caused the dent. Also thinking that's unlikely since the impeller arms are rubber and the plate appears to be stainless, so would be very hard to deform, but figured I'd ask. This is my first outboard rebuild - have done lots of 2-stroke motorcycles - grew up in the '70s so the golden age of two stroke bikes. Got the Big Twin from a relative - was dirty but in pretty good shape, 120psi in both cylinders - so a quick hone and new rings, new gaskets, ignition parts, carb rebuild, etc., and I'll be hanging it off the back of a '59 MFG Celeron we found for sale by the side of the road. Boat has good bones, will be replacing mahogany decking... I'm sure you know the drill!
Mod EDIT: Solicitation removed
Steve Casey, North Andover, MA
sphelps
sccasey , Welcome aboard ! Sorry I can't help you with your motor . But would really like to see your your MFG restoration . Please post it when you start over on the hull restoration page ... Sounds like a very cool project ..
Hopefully the guys here can answer your questions ... Good luck !
Mas
I'm thinking the "dent" came from the deep freeze while the was still some water in the LU pump area and pressed it down upon freezing. I'm not familiar with the '58, but I've only seen flat pump plates. A replacement is probably very easy to find...or you might easily hammer it out.
Mas
hardwater fisherman
I think I have seen an impression like that in at least one of my motors wear plate. I do not remember which one though. Also not sure if it was made that way or not.
Mas
Just looked up the part (0303866)... definitely the plate was flat, and a deep freeze certainly was the cause.
Mas
hardwater fisherman
I also saw the replacement plate is flat.Not all pieces sold today are of original design. I also think that if ice build bent that plate , the pump housing would crack open before that plate would bend.
hardwater fisherman
No Title
This plate is from a 1970s 40hp. The plate used to replace it was flat.
sccasey
Mod - Apologies for the "solicitation."
I'm skeptical that freezing could have caused such a deformation. Thinking that would have required the entire impeller cavity be filled with water, as the expanding ice would exert force in all directions, so unless bound on all sides, especially above, could not have deformed plate down. And weaker parts of the plate -- thin pieces near shaft hole -- would have bent first.
I also saw the new replacement parts are flat, but seeing another plate with a very similar, if longer, depression makes me think it was designed and built that way -- perhaps to create some sort of swirl effect, with a pocket of water below the spinning impeller arm...
Of course, I may very well buy a new part -- have several hundred into it already, and want this thing to be dead reliable, not stuck somewhere, overheated bc I cheaped out.
So love to see if anyone has an original '58 to compare. Just buttoning up the crank/cylinder/head now, still a little while before I get to the exhaust tube and gearcase...
Will post pix of the MFG in the hull section once I get to the carpentry.
HighTrim
Ive restored a gazillion of em! Found many with the deformed plates. As others have stated, it is NOT normal. It is from water sitting in the gearcase over winter.
Ensure your drain holes are free from debris. Mud daubers like to build nests up in there and block them. ONce blocked, water cannot drain, its sits in the cavities, freezes, expands, and does some serious damage.
It is normal to see ugly oil stained water running out of these drain holes when you pull your boat from the lake. This is the unburnt fuel/oil mix mixed in with the spent cooling water. If it doesn't, you have a problem!
Honorary Supreme Mariner
???---Have a close look at the impeller housing.---Then look at the pocket on the impeller housing.----This deformation is caused by freezing.
hardwater fisherman
????Relax I already said Okay. Your right again and I am wrong. If you look at post #4 you can see I said I dont know if it was made like that or not.
hardwater fisherman
????---By the way there is NO pocket in the impeller housing. The pocket is in the gearcase housing.
HighTrim
As a side note, you do not need to replace them. Simply put them in a vice, flatten them out and away you go. Of course as long as it is not worn or grooved on top of the deformation.
Mas
...and depending on the adjacent cavity...you may not even need to flatten. On one of my motors ('59 Seaking 35HP), I've even filled the non-circulating pockets with JB Weld to prevent any further attempt of freezing.
Mas
Mas
Here is a pic of an original pump housing...easy to see the pockets. Damage can also be done to the castings. I believe there were drain holes originally drilled, but they can close up in a heartbeat:
