57 sportwin controls
markfromohio
Thanks to you guys I got this motor running like a champ. Now I am trying to add controls and steering to the front of the boat so when I take my wife out I dont have to keep switching seats with her. Bought a nice set of simplex controls for 20$. But now I need to get the retainer clips for the trunion nuts. Does anyone know where i can get them? Do I need a part #? Also for the steering I was thinking of buying the EZ stick system, as I have no room for a steering wheel. Does anyone have this system? Is it worth the money? Is there a better option? Any input would be appreciated.:)
tashasdaddy
Re: 57 sportwin controls
connectors http://www.iboats.com/OMC-Johnson-E...18270172--**********.193377589--view_id.40267
i have had stick on several boats. here are pics with a 55 15 hp.
this is the bracket shown
http://www.iboats.com/Throttle-Cont...18270172--**********.193377589--view_id.40123
you will need the universal mounting plate for the steering tube.
markfromohio
Nice set up.. that's what I am shooting for. is the yellow wire for an electic choke? Do you have electric start also? my wife is gonna have to be my electric start system lol..
tashasdaddy
no, if you notice on top of the cowl is an aluminum pole, that is my stern light.
you can easily put a start and kill button on the console. all you would need are three push buttons. start, choke, kill.
markfromohio
camra pics 014.jpgone goes here
camra pics 015.jpgone goes here
camra pics 016.jpgI have the parts for the linkage.
Thanks for all the info. It will be very helpful. But the parts i need are the clips that keep the cables secure at the motor. My motor was missing those when i got it. i can see where they were but they are gone. I can probably rig something up. But prefer to do it right.
tmcalavy
Try Engine, Blade and Prop in Milwaukee, WI...they are online.
I forget the name of that part, I always call then them cable retainers...they have two U-shaped notches. Make sure you get the size rated for your motor...the one for Big Twins are a bit larger than smaller hp motors.
markfromohio
I believe this is what I am looking for. I found it on e-bay. They called it "Evinrude Johnson motor shift Throttle cable Bracket". This one is for a 40 hp outboard and mine is only 10. And they only have one and I need both. Anyone know the proper name or part# for this part? Or where I can get a set?
