Folks.
I am stuck. I have a 57 1o hp that I cant start. I had it running 2 weeks ago for 2-3 min but now it wont run. I have changed plugs, points , condensors, wires and have a hot looking spark. I held the plug and pulled the rope and it hurt like burgeevers.
I cleaned the very fould up carb twice and rebuilt it. The only problem I can see is I couldn't get one of the replacement o rings in that goes around the low speed needle valve but used some maroon spacers and washers that fit very tight.
If I pull the rope a few times it stinks like it it is flooded. The barrel it is siting in has alot of oil and dark stuff floating in the water.
I talked with a small engine guy who asked me if there is a way to adjust the timing. The only thing I can think of is how the screws in the magneto plate are ligned up with the screws that run through the points.
I wonder if it could be reed valves? I was told these almost never go bad. I have alot of time in this thing and currently it would make a better anchor than a motor.
Thanks for any help.
Frank
Frank
