Hi I have a RDE-19 35hp, it is verry slow to crank. I got this motor last year and don't know any of it history, was told it runs. Ok here is where I'm at when in try the stater it cranks so slow that it will not build up speed to run (crank, 5sec, crank, 5sec) and so on. New battery, rebuilt starter, rebuilt carb, good spark, 125psi in both cly. If I take the plus out it cranks great, one plug in cranks hafe as good; but runs, put other plug in back to same problem, (no differnce if I have the top or bottom one in). Spent a lot of time playing with it and dit get it to run (with both plugs in) ran it for 30min thinking it needed to clear out or something. Turn it off and same thing.
