cheburashka
Thread starter- Joined
- May 28, 2005
- 715
Finally got my '61 Glasspar G3 in the water with a '57 Lark. Once I got the throttle dialed in and fooled with the motor angle, I was able to get it up onto plane pretty easily. The problem I'm having is that this boat rides with the nose very high, so even though the anti-cavitation plane is level with the bottom of the boat, when I'm on plane it sits around 2" below the surface of the water. It's hard to measure, since when I go to the rear to check, the weight distribution changes, but I'm certain that the plane sits below water level when I'm at full throttle. The boat makes a huge wake for such a small boat. Where does the anti-cavitation plane usually sit in relation to the level of the water at the rear of the boat? When the boat is on plane, should the driveshaft tower be perpendicular to the water?<br /><br />Thanks for your help,<br /><br /><br />Steve
