57 Johnson 7.5 prop nut cap
ninhalo5
Hi guys, I'm ready to freak out here. Today as I was going up the river I hit a rock or something and my prop cap came off. I didn't notice until I put the engine in neutral then the pin fell out. It appears that this part omc 0303365 is now obsolete. And there is only one place left I can find that has it but they want a ridiculous amount of money for it.
How imperative is this part? Could I just put a new pin in and cover the holes with duct tape, a rubber O-ring/grommet or something?
Is its only purpose the keep that pin in place or does it do something else like protect the nut from water?
Thanks
boobie
Re: 57 Johnson 7.5 prop nut cap
If it was my mtr I'd find the correct one. Maybe somebody else will chime in with more info.
ninhalo5
Thanks CS that cone is a good bit different than mine. I found 1 on eBay for $30 but that's ridiculous. Just a couple years ago these things were going for $6 but I guess obsolete parts will cost you more.
I bought a steel pin and found a grommet just smaller than the props clip it was a tight fit but i got it all togetherand holding well, it looks like it may work, but I haven't tested it out yet. Guess there's always the possibility that the grommet will slide off in the water.
boobie
How much does a new prop cost if you lose it due to not having the proper nut ??
