Re: 57 Arkansas T 14' TRANSOM WOOD REMOVAL
Okay here is the solution
Welcome to iboats.
Yes .....make a template for the correct shape of the transom. You will need to install the new transom in 4 pieces (yes 4) and here is the trick.
The pieces need to be 3/4" thick (assuming you are going for a 1 -1/2" standard transom. The wood will be bonded/glued in place. Do not bond the wood until it is installed but you must still seal all the edges. Install the first piece which is closest to the aluminum in 2 or maybe 3 pieces. Put it together like a puzzle. Then the next layer the same way but with offset seams. I would use epoxy to glue it together and shoot 1" (or 1 -1/4") stainless steel screws into the pieces to aid in the setting of the epoxy. Leave the screws in place and just seal over the heads.
When you are done you will have a strong transom.
Get some epoxy supplies here >>> this will work fine and a good bang for the buck
Low Viscosity Epoxy Resin
The iboats store has gluvit too which is essential to prevent all future leaks
gluvit
I highly recommend that you DO NOT remove those rivets on the knee brace!
