smoken
Thread starter- Joined
- May 23, 2009
- 11
new to outboard world Dad passed away I got his 1957 seahorse 5.5 put in drum of water ran fine took to lake couple times 3rd time out hard to pull start run a minute and die found this web site started reading (very good bunch of people on hear) took apart installed new coils, points, condenser,
plugs gap 20 plugs 30 installed new water pump cleaned all up still hard to pull went step by step and with lower end apart turns over good but can not find anything obvious is the lower end supose to be tight or a little lose have to force propeller on and shaft gears kinda lost any help appreciated sorry so ;ong just thought the more you knew the better
smoken
smoken
