'56 Merc MK25E, where can you get controls?
tallcar
I wish to have this motor run with controls, but it does not connect like a Johnson/Evinrude does, What type of throttle/transmission controls do I need?
Chinewalker
Re: '56 Merc MK25E, where can you get controls?
Hi Saltydawg,<br /> Actually, it can connect similar to a Johnson/Evinrude control with the right accessory connectors. The throttle will require an anchor point on the starboard side cowling and the access slot in the cowling (which may have a 4-inch long cap in it) would allow the throttle advance to connect. That connector on the throttle linkage would be a threaded rod with a T-pin in the end that the throttle cable would lock over. <br /> The shift side is a little more complicated, as you'd need the U-shaped handle for the front of the motor. This handle would also incorporate the steering anchor point. There would be a triangular shaped pivot piece on one side of the handle that would then be attached to the shift handle that come out from under the carburetor. There should be a hole in the middle of that handle. <br /> I am pretty sure that if you were to visit Grubb's Marine (www.oldmercs.com) you could order a complete parts list for your motor, and ask if it has the remote linkage parts included in it. The parts list also includes blow-up diagrams.<br />- Scott
tallcar
bump
tallcar
thanks for the reply Scott, I will look into it :) <br /><br />Richard
Laddies
Banned
hes yourm engine have the connecter kit on it or do you need that to I think I have a neighbor with a box and cables they are probably the wrong length if I knew what you needed I could ck on them for you
Laddies
Banned
sorry about hes yourm should have been has your engine,
