56 lightwin 3hp doesn't reach full throttle. New to forum
56lightwin3
Hello everyone, I'm new to the forum but read everything I could find about the lightwin. I am very impressed with what it does, even though it's only 40%. I apologies for the long scattered post, but I'm doin my best to give all the info I can on 'er.
I'll start with info about it.
It is an evinrude lightwin 3hp. 1956
Was all original from what I could tell, other than carb kit a few years back.
Supposedly ran when kit installed.
What I've done.
I put all new ignition in. Coils, points, condensers, plug wires, plugs.
Cleaned tank, filter, line, carb, and carb kit.
I'm not sure if I have the needle packing correct, but it doesn't seem to leak. I have not sprayed carb cleaner around to see if it revs or not.
I have fuel with tcw-III oil mixed at 24:1
Points are set at .020"
Has good spark.
~70psi each hole cold
Cap vent is clear
I can touch head when it's warmed up so I think impeller is good.
Now for the dilemma. Get it in the water on my 12' aluminum boat, pull it over and starts on 3rd pull with needles at 1 and 2 turns I think. Whatever that guy on the lightwin website said set em at for initial settings after carb clean. It chugged along descent, played with low speed needle and it idles great. Go to turn throttle up and after about 40% it just stays the same. I tried playing with high needle and it helped a bit but not much. Then it starts boogyin for about 3 seconds, then tapers off to half throttle or so, then back up to speed and back down again. It would do this all day I believe, but will not hold full throttle. I took it home and cleaned cap vent which was plugged, tested if carb float floated and it does. I have a good fuel flow. I set points to .020" because I didn't set them before the first run.
I then took her out again with some tools. Still idles awesome, but won't even touch full now like it did before, no waver, just half throttle no matter where high needle or throttle lever, as long as it's over that 1/2 mark, it just sits at half and runs so-so. Checked spark in both holes, great. Pulled one wire, then the other, and it ran the same when I pulled either one, but ran a little rough with only one wire on obviously. I know the high needle is banged up from some idiot turning it closed too tight, that might be the problem.
I'm hoping someone here can give me a direction to go in, or sell me a high speed needle. Any help or advice would be great, and again sorry for the long post.
Bassman86
marine engine has the part you need i think its like 35$ though, you may find a carb rebuild kit somewhere that has all the parts.
Bassman86
if this is the right carb.. i dont know your model or any of that.. im having the same kind of problem as you in my 9.8 mercury though so ill be watching to see what you come up with for a fix..good luck!
