twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
After sitting for many years I finally tackled a QD17 that had shifting problems. I tuned it over the winter and it's up and running. I opened the lower unit and nothing appears broken. This is my first working on a lower unit as I usually find it easier to swap out a complete unit. The best I've been able to decipher is the lower shift rod is off a little. If I move it (probably less than a quarter inch) I'm able to have it hit forward, reverse and neutral as it should. Question is: Is a (slightly) bent lower shift rod a common occurrence and what could have caused it? I intend to bend it slightly to get her to shift as she should. Other than that I can't find anything wrong. Any input on this is appreciated.
