5500 Rpm at wot trimmed up 45mph ish
ziggy
Re: 5500 Rpm at wot trimmed up 45mph ish
read this ss. then bring in some facts for us so some folks here can help ya out.
Bt Doctur
Maybe for a jet-ski, what is it?
thumpar
Depends on what you are driving. If it is a car I would say no. If it is a boat maybe.
Sevenscrew
Mercruiser 3.0 lx 135? hp alpha one
Bowrider 17 foot. 92
Soorry can't tell u the model or serial it's rubbed off the air hat
thumpar
RPM seems pretty high. Is that GPS speed?
thumpar
RPM should be in the mid 4000 range. Also check speed with GPS. What prop are you running?
ziggy
wot spec for a 92 3.0lx is 4400-4800 per s/m 13. so imho, something is amiss. tach reading wrong, or really is turning that rpm in which case ya'd want a steeper pitched prop. or maybe your trimmed out to much and yer ventilating the prop getting the high rpm readings.
what does the tach read when your not trimmed out high? does that bring the rpm down into specs?
Sevenscrew
Ill get back to you Wednesday . When I have it out again
Don S
If you was under propped enough to be 1000 rpm to high, you wouldn't be seeing 45 mph.
You have tach issues.
