Re: 55 hp chrysler 1973 starting problems
thanks j
i cleaned that jet but set it back to 7/8 open because thats the way it was. but i will try it at one full turn.
thanks bob,
hi i just bought a 55 hp chrysler 1973 outboard on a 1971 bass bomber and it was running but sputtering at idle. cant seem to get it running and stay running so i rebuilt the fuel pump and then tried to start it. it started and stayed running for about 7 minutes. Then it shut off and i could not get it started again. I also rebuilt the carb. i set the air jet to one full turn out. i am getting spark from the spark plugs but it will not fire. i put in new champion L82c plugs and replaced the fuel lines. now i cannot seem to get it to fire at all. i also took off the fly wheel, regapped the points, and still cannot get it to start. i'm not sure these are the right plugs maybe i should use L20v?
is there any ignition switches, breakers, condensors, or solenoids that may be weak or stopping the motor from running? if so, how can i check it?
Any suggestions, would help greatly. We are leaving Thursday to go to Canada fishing and really need to get this motor fixed.
Thank you for your time.
Duane
