Spartanfalcon
Thread starter- Joined
- May 1, 2012
- 25
Ok, first time poster... long time reader!
My trusty 55 hp Chrysler was winterized and then refilled with L.E. lube. After the plugs were put back in it started leaking from the fill plug. THEN, replaced the upper & lower plugs with new plugs and rings. Same problem developed. It didnt start right away... but it developed without any running time in between. What will it take to fix this?
Now, here's another twist to the story. I dont think they are connected but then again I'm newer to the boat/outboard ownership deal (3 years, thank you very much!). I also noticed when the new plugs were put in that a hole that a 1/8" drill bit might fit thru has developed right next to one of the bolts that connects the lower unit to the upper. I'm almost positive this happened from a wrench but surely wasnt me! possibly when the local marina sealed the lower unit for me last spring.
Any suggestions would be GREATLY appreciated!
ps... if you're really in the helping mood, why is there "excess"/unburned fuel found around the motor after a day on the water? I'd say about 3 ounces total... but NOTICABLE.
THANKS!!!
THANKS!!!
