55EvinrudeFan
Thread starter- Joined
- Jul 14, 2008
- 4
May be a silly question, but I purchased a 55 Evinrude 15HP a couple years back and haven't had time to work on it until this past winter. It ran, be it rough when I got it, I did a complete tune up and fired it up this past weekend. What I can't remember is where the water is suppose to exit from the water pump. My 3 hp has a plate with holes on the front side of the shaft housing. Where should I be looking on the 15HP? I fired it up, didn't see water and shut it down. I pulled the lower unit with the intent to replace the impeller and found it good shape. Although it may need some seals replaced as it was covered in lower unit lube.
Thanks for the help...
Kevan
Kevan
