55 chrysler
R1R1T3
2 Questions <br />(1) what is the oil mix ratio<br />(2) where do you place water muffs to run this unit on land<br />Thank you
eurolarva
Re: 55 chrysler
gas to oil mix is 50 to 1 using a TCW3 Marine oil. It is better to use a garbage can with water then the muffs. Most muffs wont work or fit on a chrysler. The water for the water pump comes in the 8 small holes in the area where the lower unit bolts up to the motor leg. Unless you have special built water muffs for a chrysler your muffs wont work. What is the year and model of the motor?
R1R1T3
Re: 55 chrysler
Not sure year<br />Model 559HC<br />Serial 6149
