54 cd-11
Rlkelsey
Just picked up what seems to be a really great little motor. After feeling somewhat suckered by a pretty little gal selling it for her fiancée, got it home and started to do some research. Now I don't feel too bad. The motor came without tank or lines, so I got an education on pressurized systems, ans have ordered parts. Carb kit with new float and Oregon 07-700 pulse pump on the way. I have the carb off and disassembled (clean, just a little shellac in the glass bowl) and can't wait for my parts! I love this old motor, my gramps and I restored a 40's vintage Evinrude back in the day. Good spark, will compression test on both cylinders tomorrow. All that to say, anyone have a line on intake and reed plate gaskets? I have plenty of cork, with the scotch hi temp adhesive be good, or will cork not do? Thanx for any ideas.
Rlkelsey
Havent pulled the flywheel yet, but will over the next few days while i wait for parts. I get no sealant on those gaskets, is there any pproblem with making my own cork gaskets?
F_R
Personally, I wouldn't use cork. Use gasket material similar to the originals.
Rlkelsey
Will do. Pulled the flywheel last nite and the coils, condensers, and point are all brand spankin new. The carb was incredibly clean also, but will put in the new seals anyhow just since I have it apart. Other than going through the lower end, I'm sure she'll run fine. Just need a fuel setup with the newer connections and I should be able to test in the barrel. Thanx for your advice, Russ
Rlkelsey
Ok, been a couple weeks since I have been able to put hands on this thing. Got pump installed, hoses routed and replaced plugs. Replaced flywheel and for some reason have little to no spark on either cylinder. Is there a certain timing thing I'm missing on flywheel install? Thanx for any help.
HighTrim
Step 1 dress points (wet/dry around hacksaw blade works if you do not have a points file)
Set to 020, then pull a business card or paper stock through them dipped in acetone or laqeur thinner.
If that does not help, test condensors and new coils. Ensure plug wire is twisted into coil and has good connections at coil, and at spark plug boot. Ensure good continuity of plug wire.
Rlkelsey
Had good spark before pulling flywheel. Thinking may have tugged plug wires loose, Condensors, coils, and points are all brand new, points were gapped properly. With they key in the shaft, obviously no wrong way to put it on, but is there any timing issues I should know of?
nwcove
Do I need to have the motor in gear to produce spark?
not much chance of tugging the plug wires loose just from removing the flywheel. if the points are clean and gapped to 0.02 the timing is taken care of. no need to be in gear to get spark. as Chris mentioned, be sure that the plug wires are screwed into the coils and the connection at the boot is good. also take a close look at the smaller wires coming out of the coils....are they chaffing on any rotating parts?
F_R
Don't fall into that old "points are brand new" trap. You would be surprised at how many brand new points have an invisible layer of non-conductive film on them. Clean them. Then if you have a multimeter, test them. Should show zero ohms resistance when closed, as measured on lowest range of your meter. Not a couple of ohms, or an ohm,.....zero.
HighTrim
Yup, don't think Ive ever put a set of points in that had perfect continuity. Always dress and clean, even brand new.
cajuncook1
If your looking for a help cleaning your points and testing your ignition, then here are some YouTube videos that can help.
Not professional videos, but they can help guide you through ignition diagnostics and repair. The motor in the video is a 1968 Johnson 6hp.
I posted this to help another member, it may help you with the ignition.
Hopefully will give you a visual and help you some.
Evinrude Gale and Johnson ignition video 1
Evinrude Gale and Johnson ignition video 1 - YouTube
Evinrude Gale and Johnson ignition video 2
Evinrude Gale and Johnson ignition video 2 - YouTube
Evinrude Gale and Johnson ignition video 3
Evinrude Gale and Johnson ignition video 3 - YouTube
Evinrude Gale and Johnson ignition video 4
Evinrude Gale and Johnson ignition video 4 - YouTube
Evinrude Gale and Johnson ignition video 5
Evinrude Gale and Johnson ignition video 5 - YouTube
Evinrude Gale and Johnson ignition video 6
Evinrude Gale and Johnson ignition video 6 - YouTube
Evinrude Gale and Johnson ignition video 7
Evinrude Gale and Johnson ignition video 7 - YouTube
Fuel bowl and filter:
Clean out the sintered filter element in the glass bowl in a solution of half water/half pinesol. Use good hot tap water and let set for a couple of hours and blow out with compressed air. Re-Soak if need. You will be surprised at the gunk that comes out of that filter element. Once clean you should get much better fuel delivery.
Rlkelsey
Picked up a little 16 ft Silverline runabout with a 67 johnson super seahorse.
Have been having a heck of a time finding a flush out adapter. Anyone have a line on one of these?
nwcove
those flush adapters are quite rare, but you do see one on ebay now and then. you could try the aomci site, but i doubt any one would let one go.
you can make one if you have a few basic tools and are a handy sort.
