53 Fleetwin mystery part help?
Nappymop
While disassembling the lower on my newly inherited Fleetwin a small brass pellet shaped object was sitting on top of the water pump. I would love to post a picture, but every time I try the forum tells me it's a invalid data file. If anyone has any ideas what this could be I would greatly appreciate it.
Also if anyone has a parts manual handy that may also help.
It's about the size of a .22-pellet, kind of shaped that way too. Like a small cap or end piece. It's brass.
Thanks,
Greg
F_R
On top of the water pump? The only way an object could get in there would be if it came in through the water intake and pump. But what you describe sounds way too large to make it through by that route.
---OR---maybe it came falling down from above. The area above is the cooling system route to the powerhead. The only thing I can imagine is it may be a plug that has fallen out of the swivel tube/driveshaft housing. That part has an integral water tube cast into it with various plugs, not shown on the parts list.
Arrgh, I just tried to upload the parts book page and it said it is too large. I'll have to see what I can do about that.
F_R
No Title
Trying this again,
Nappymop
Thanks, still working on getting a picture uploaded. It keeps telling me invalid days.
F_R
F_R
No Title
This is NOT your motor, but it is the only thing I have apart that is similar with the brass plugs in the driveshaft tube. I don't even know if your 7.5 has such plugs, but it is a mighty good guess, I think.
gm280
Surely it is not a ball bearing ball from the lower crankshaft main bearing... I sure hope not... I did have that happen to me. So...:facepalm:
Nappymop
No Title
photo225056.jpg Heres a pic, its hollow and not threaded
F_R
I confess, I don't know. Water restrictor?? Can you see where the water exits the cavity above the pump? Any chance it fits there? As I said, I dunno.
Nappymop
You know it's entirely possible that in 20 years of sitting a kid or some thing put that in a hole. I can't find that piece in any manual.
