sundancekid
Thread starter- Joined
- Sep 12, 2009
- 5
Just recently picked up a 52 mercury rocket 7.5 hp motor. It's been sitting in a garage for at least 5 years. I got it with a boat and trailer combo from a friend. I'm a weekend mechanic but don't know much about outboard motors. I'm assuming that it's a direct drive because I don't see anyway of engaging a drive gear. So with that in mind when I pull the cord to turn it over it's a little stiff to pull. Is this because it's trying to turn the lower drive uint at the same time or something else. Should it turn over as easy as lawnmower? I've pulled the plugs and did the whole finger over the hole and it feels like it has some compresion but don't know how much. I'll be putting a comp gauge on it on my next days off to get a good reading. Does anyone know what kind of numbers I should get? Next is the fuel system. It's gunked up pretty good. I'll replace the lines and inline filter and take the carb apart to clean it but how should I go about cleaning and flushing the tank? Is there a good solvent I can use? I guess I need to ask if these are worth putting any money into or should I look for another motor? The boat I got with it is a 1960 14' crestliner that I want to use for fishing and tooling around the lakes/ponds. Any and all help is needed. Thanks Dave
