trebot
Thread starter- Joined
- Jul 7, 2004
- 102
Have barnfind '54 Model/Serial 15012 - 23506. Someone has been into top end (magneto area), and I' m not sure how to put the cam / key / flywheel back together.
Have straight bore cam w/keyway which slides over non-taper portion of crank. It sits below crank keyway against the crank bearing. What locks it to crank? There isn't a seal in the housing, which would raise cam, but then the cam would spin on seal?
Found a coil spring in a bag in shroud. Does this go below cam to raise it higher on crank?
HELP
HELP
