50hp Thunderbolt suddenly won't go above idle
waflyboy
I was cruising with my 1976 Merccury 500 today. It fired up easily and ran like a champ at 3/4 throttle for about 10 minutes. Then suddenly the RPMs dropped to just above idle. (It was a very fast reduction in RPM, as if I had chopped the power.) I couldn't get it much above idle the rest of the day. If I applied power, it felt/sounded like the engine was loading up, but the RPM wouldn't increase.
Idled back to the ramp against an outgoing tide... long ride!
When I returned to the house, I took the plugs out. (They have perhaps 10 hours of use on them.) They were rather black and appeared to have specs of carbon on them. I replaced them with new ones and started it in the driveway - started right up. Going to put it back in the water for a test run next weekend... but before I do, I'm wondering what else I should check.
What can cause a sudden power loss like that?
Gas was brand new and ethanol free
carbs and fuel pumps cleaned and rebuilt last year
Maybe I misadjusted the carbs and it's been running rich ever since... and the plugs just "gave out" suddenly? Don't think it would work like that, though.
Thanks in advance.
