50hp Lark control box help
Bee Reel
I recently bought a 1972 evinrude 50hp lark with hydro shift model number 50273c and it has no control box. I found a control box online for sale from a 1970 85hp lark with hydro shift. Are the 1970 controls compatible with my 72'?
F_R
Honorary Supreme Mariner
Re: 50hp Lark control box help
In the first place there is no such thing as a 1970 85hp Lark. A Lark is 40hp. An 85hp would be a Starflite. Going beyond that, neither one would be compatible with your 50hp. 85hp has a totally different kind of electrical system, and a 40hp has a different electrical system as well as a different shift switch. You need to look for a control with a yellow plug on the aft end of the electrical cable. That yellow color identifies it as the correct control. It was only used a couple of years, and only on the 50 and 65hp models.
Bee Reel
Gotcha. Will see what I can come up with. This might be a tough one.
Bee Reel
Does anyone have a picture of the correct control box for my 72' Evinrude 50hp. I found one at a local boat consignment shop and it has a yellow plug along with the harness. Just want to make sure its the correct one. Thanks everyone!
F_R
There was only one box with the yellow plug. Well, two if you include the Johnson version. They are interchangeable. Evinrude had push button shift, Johnson had a switch that was operated by moving the throttle handle. Exploded view parts books are available at Evinrude
Bee Reel
Awesome! Thanks so much. That should make it much easier!
