50hp Force is hard to start
TOMMYTJC
I am having trouble starting a 50hp Force outboard,no. 507f4a, 1457. Sometimes if I switch the plug wires it will start and run fine untill I stop the engine and try to start again. It cranks fine and I have replaced the plugs several times. I put the hotest recommended plug in. Please tell me where to begin to find the problem. :(
dkondelik
Re: 50hp Force is hard to start
Afternoon TOMMYTJC,<br /><br />Switch the plug wires?<br />????<br /><br />Have you pulled the flywheel off to confirm that the key in inplace/in tact in the shaft?<br />Verify the magnet(s) have not come loose.<br /><br />Let us know what you find.<br /><br />Good Luck<br />HAVE FUN!
scotiany
Maybe you should try a "colder" plug.
