johnson owner
Thread starter- Joined
- Apr 11, 2015
- 4
I have a 50esl72 johnson that wont do anything, I finally jumped two wire in the control box and everything works but no spark, Checked everything i know to check and all looked good. Someone said to remove top yellow and green wire in power pack and check for spark. I did and low and behold there was spark. So I am assuming the engine might be ok but my problems lie in the the remote control unit. I dont know what to do next. Has anyone run accross a similar problem? What was the solution. Also this is an electric shift if that makes a difference. Oh yah the reason I jumped the two wire on the starter switch was because the sensor that senses neutral seemed not to be functioning. Could that be the whole problems. Tried to find a replacement but no success. Is there a way to by pass this senssor? Thanks for any suggestions.
