5000rpm starts to stall
Nickledimed
At about 5000rmp ingine starts to stall.
Changed fuel line, bulb, tank, intank filter, rebuild fuel pump.
If I reach back and pump the bulb, the engine will come back to life.
The bulb doesnt seem to go soft, but the bulb doesnt ever get hard either.
Its done this since I bought it back in feb.
Im just tempted to put an elec. fuel pump on it.
Any reason why not?
Also, any suggestions on one?
See boat info below for more info.
Thanks for being here.
Barnacle_Bill
Re: 5000rpm starts to stall
What year motor? Electric pump not a good idea due safety reasons.
daveswaves
Ensign
You need a minimum fuel pressure of 4 to 4.5 lbs to feed that engine above 5000 rpm. your fuel lines could be too small or the fuel pump rebuild was not done correctly. Solve the fuel delivery problem first. There are screen filters built in to the top cover of each fuel bowl. They can become restricted as well. There is a merc bulletin that suggests removing them. Opinions vary but I remove mine and run a good quality fuel filter between the tank and the fuel pump.
Nickledimed
sounds like a plan..Ill check into that either today or tomarrow.
Thanks
Nickledimed
Removed the intank screen/filter, installed an inline filter and the thing runs like a scalded dog.
