50 year old lower unit shift cable retaining nut frozen
Deep waters
1975 Mercruiser mc-1(?) outdrive upper ID #4005769, Engine stamped 828756 and metal tag at bell housing 3968973. The lower shift cable needs to be replaced. The retaining nut was grimy so I cleaned it up so the tool, a 9/16 socket, would fit well. Also the nut was submerged in penetrating oil for 24 hours. The retaining nut was frozen and now the nut is rounded because of my attempt to remove it. Would preparing the nut for any easy out be worth trying? The unit has the "new style" nut that threads in from the front side not the back side. Or is there a better method to get the nut out?
reginaldo
I'm interested to learn more about this problem but am having issues visualizing things. My from-the-hip response is heat (maybe a small butane torch for precision) and a vice-grip?
As far as the easy-out goes do they work for nuts or are they more for bolts?
Additionally how much space do you have to work here? Good luck
Deep waters
Thanks for the inquiry Reginaldo. Here are a few pictures for you
reginaldo
I would personally try a vice grip or needle nose vice grip and heat the surrounding area--wiggle back and forth wit hopes to break loose.
Next steps might likely be cutting the cable off and easy out like you mentioned, or drilling out. A 90-degree drill extension could help too
kenny nunez
Get the largest vice grip pliers that have the diagonal cutting teeth. Reach around the front of the bell housing biting the jacket and pull back hopefully the jacket of the cable will pull out of the brass fitting. If it pulls out then you can drill the brass fitting in stages to the tap size of 1/4” npt to clean the threads. Forget easy outs they cause more problems.
The reason you want the jacket removed is the wires in the jacket are very hard and you will just dull your drill bits.
I always hated that style of cable. I never had a problem with the earlier style. I was a Mercruiser dealer for over 30 years.
Good luck
dingbat
Guys, the correct thread is 1/4 x 18 NPST NOT A 1/4 INCH PIPETHREAD
I developed a thread repair for housings that have stripped the threads completely pm me for specifics.
A machinist for many years.
No such thing as NPST thread designation.
I’m assuming you mean 1/4-18 NPS (National Pipe Straight) which requires a 0.453” tap drill.
kenny nunez
Very slick repair Doc.
Before the rear entry cables came out I just used the pipe tap to clean the threads. Then even for the rear entry ones that started showing up I would still replace the cable with the earlier style.
For the original poster be sure to clean out the cavity where the slider goes for reverse. You will not believe how much grime is in there.
