I have a 1986 50 HP model E50dTLECA. I have removed the prop, prop seal housing, the two rings, the first gear, the shaft gear, the drive shaft, placed the gear in the down position and I can still not pull out the prop shaft. I can not see any thing else to remove. I can't imagen that I need to take out the clutch dog spring to remove the clutch dog before i can remove the shaft. O yes I have removed the gear shaft. As i have looked through forems and youtube and manuals the ony thing i keep seeing is making sure the gear is in the down position. I feel it is down, every thing is loose, the shaft, the clutch dog, the rear gear but the shift gear housing will not budge. I dont want to force it for fear of breaking something. Thank you for any help.
