50 HP Evinrude will not start
schmitz46
I went to dig the boat out of storage over the weekend, hooked up a fully charged battery, turned the key, and nothing. The motor doesn't even click or try to turn over. I would say I am decent with fixing things if I know what to look for. I had a buddy come over as I was stumped. We were able to jump the starter from the solenoid to get it to turn over. I have power coming into the solenoid on the top post, but no power anywhere else. Thought it was the starter solenoid, so I went out and bought a new one. Installed it, and still the same thing. My unit has the electric choke which is located right by the key switch. With the key in the on position, the electric choke works just fine. I have checked the 20 amp inline fuse as well which is fine, I have power on both sides of the fuse. I also took the white wire off the switch that is located near the throttle arm on the block, and that didn't work either. I am completely stumped at the point and don't even know where to start to look. Any help would be greatly appreciated!!! The motor is a 1971 50hp Evinrude. I could get the model number when I get home later in the day if need be. Thanks again for any feedback!
pn
kill switch or neutral safety switch
Bosunsmate
might be your key switch isnt working on start position too.
Your neutral safety switch is on that motors engine, Ive never tinkered with one but i think it grounds out any starter signal when the motors in gear, so if thats malfunctioning you could try and bypass it and see if that woorks.
theres always thepossibility of a wire corrupted between the engine and control box too
Honorary Supreme Mariner
?????---When the white wire is held to a ground on the block will the motor crank.---Yes or no.
