50 force props
scoverall2
I have a 17 ft alum bass boat with a 50 force motor running a 10-12 prop , rpm is to high and speed is low do they make a 10-15 prop for this motor 14 spline with pin
Frank Acampora
Yes! But you do need to look around a bit. If you go to ebay and search Chrysler Force props there may be a couple there. 13 1/2 is easier to find but I have purchased a couple of 15 pitch bronze two blade props. Disadvantage is the two blade props tend to vibrate more.
