Re: 50 Evinrude sunk & revived
heh heh, <br />If you really want experiance, read what Joe Reeves has to say about all things OMC related.<br /><br />you need to apply power to the controller (with it disconected from the engine) and measure the green and blue wires with a voltmeter. <br /><br />The controller for a selectric/electramatic gearcase will have 0v on both wires when in neutral. 12v on only green wire when in forward, and 12v on only the green wire when in reverse. <br /><br />The controller for hydroelectric will have 0v when in forward, 12v on green when in neutral, and 12v on both green and blue when in reverse.<br /><br />They cannot be swapped between the two.<br /><br /><br />P.S. <br />If you use the wrong controller with the hydroelectric engine, you won't get revese, and forward and neutral will be backwards, If you used the wrong controller with the selectric/electramatic, you would break something when you select reverse.
