50 amp fuse blowing
full stringer
hello gentlemen, i just removed batteries cleaned terminals cleaned volt regulator terminals on old floor mount style, removed positive alt cable from alternator and cleaned it , since then i installed a battery that was not used and dead sat for 3 years took it to the boat today to test its power after charging it well after i hooked up cables the 50 amp fuse for power to everything keeps popping. what the hell is going on the last thing i did before i removed my two original batteries was to crank engine over and it cranked over no problem could the problem be just this neww additional battery i tried on the system?:confused:
Re: 50 amp fuse blowing
So you had two batteries and installed a third is what you are saying? Also don't know what you mean by a volt regulator floor mount style! Voltage regulators are usually installed on the engine or are built into the alternator.
full stringer
i know but this has an external volt regulator/surge interupter omc mechanic said that late year omcs came with them? and i only hooked up the new/used battery just to test it
jhebert
Ensign
When you have a problem in an electrical system where there is a storage battery, the first component to suspect is the storage battery.
Outsider
The 50 amp fuse will blow under reverse polarity. Something may be wired wrong ... :redface:
full stringer
i was told by a great omc mechanic in stanton ca. if a battery is fully discharged and hooked up to a charger backwards then it will charge as such reversed polarity the pos becomes the neg post and like wise ( new info to me) he said he has seen this many times in his 30 years being a mechanic
full stringer
does the connection of the big red wire on the alternator have to contact only the stud i mean if it is touching the body of the alt will it cause a problem this goes for the volt regulator box as well thanks to all whom replied
full stringer
its a metal box with two wires on one side and one wire connected on the other two studs are positive leads with the big red alternator wire on one post and a 12 guage orange wire on the parrellel post. the back of it has a big black gground wire commimg from alternator attached to post maybe the positive wires are contacting the body of this unit?
full stringer
Problem solved!! It was the positive alternator wire grounding out because it was touching the alternator body. I dont think i damaged the alt because i fired up the boat and the batt/alt meter would rise upon accelleration just as it used to thanks to all of you. especially a similiar post by chopper dog. man i love this forum.
Big red wires are carrying +12 volts and cannot touch the metal shell or any other wire that may be a source of ground or you get sparks and blown fuses. It's called a short circuit.
