5 H.P. Sea King
heratio
I have acquired a 5 hp Wards Sea King.<br />The manufactures name is worn off of the plate, but has these numbers stamped on it.<br />J500 11060<br />372133 <br />XTV 27005B<br />It is air cooled, and I suspect that it was made by Clinton.<br />I have two questions, what is the proper fuel to oil ratio for this engine?, and does it use 90 w in the lower unit?<br />It has two screw plugs in the housing.<br /><br />Thank You
JB
Re: 5 H.P. Sea King
Howdy heratio.<br /><br />Welcome to iboats. :) <br /><br />Can't help you with the year, but you want to use a 24:1 ratio with chainsaw oil for fuel mix.<br /><br />The foot uses 90W.<br /><br />Good luck. :)
tntkane
Re: 5 H.P. Sea King
I just got a 5HP clinton J500 1101b ser 370793<br />lower unit looked like it was packed with wheel bearing grease. I heard that I should use lubriplate 205 for this engine.
horsefly38425
Re: 5 H.P. Sea King
if the seals are bad some people pump them full of grease/i have one that i have run 10yrs like that :)
tmcalavy
Re: 5 H.P. Sea King
Outboards that are direct drive, ie. no gearshift for FNR, where you pivot the motor 180 degrees to get reverse, are best serviced with Lubriplate 105 engine building grease rather than lube/oil used in later gear-shift outboards. Either way, if you ever find water in the LU, time to replace the seals or take corrective action.
cedarjunki
Re: 5 H.P. Sea King
any idea on the year? i just picked one up just a few serial numbers different.
steelespike
Re: 5 H.P. Sea King
J500 appears in 70 and 71. My after market manual indicates gear case uses outboard motor gear lube.Fuel mix:: indicates a quality outboard motor oil.48:1 ratio on 5hp up.My research indicates TCW3 oil may be used for all 2 stroke applications.
