5.7Gsi start with no outdrive?
ChrisCraftFan
I would like to get the engine running and set the timing while i wait on part
s for the outdrive. I do not know what the coupler looks like so i don’t know if there are any issues running the motor with no drive attached. Any issues with doin that?
I have hooked up the blue connector so I can hook up to the hose for raw water supply. Just wanted to make sure i don’t mess something up running it.
Thanks in advance
Phil
Ayuh,..... It'll be fine so long as yer supplin' water to the raw water pump,....
Saline Marina
Agreed, and also depending on the state of assembly, you could "jump" the lakewater pump on the crankshaft and supply garden-hose water direct to the hose that supplies the thermostat housing from below.
hook garden hose directly to the inlet of the raw water pump.
or shove end of garden hose into the raw water hose hanging off the transom shield and duct tape in place.
Ayuh,...... I "Think" that will cause the raw water pump to run dry, which burns up the rubber impeller,......
Saline Marina
Yes...very very good point. I was thinking that was a potential route if the lakewater pump was not yet even assembled and it was desired to test the base engine before a lot more assembly work took place, however I did not state that thought :)
