5.7 water temp sender
issue finding sender / sensor
  • need help
    Votes: 0 0.0%
  • confused
    Votes: 0 0.0%
  • Total voters
akamoonman
Im attempting to find water temp sender for my 5.7 GM 350 V8 disign 1. My issue is that there are 2 senders or sensors on the thermostat housing. The right side has 1 wire attached to the sender and a black ceramic looking object on it. The left side has 2 wire attached to it and i believe the part is 806490T. can i replace both sender using the same part. im so confused at the moment.
Ayuh,...... Welcome Aboard,...... One of those 2 is the temp sender, for the gauge, it senses varyin' resistance to ground,....
The other one is a temp switch, for the alarm system, which is a make, or break switch,....
Post yer motor's serial number, 'n one of the boys will probably look up the part numbers for ya,....
akamoonman
Thank you for the welcome.
Il check out the serial number this evening and revert tomorrow with the info.
Thanks again.
akamoonman
I know it is a 1991 Mercruiser 5.7 with a 350 V8 GM motor 4 BBl carb.
However I will look for the manual tonight for the SN Number
