5.7 Rebuild
JP6438
Re: 5.7 Rebuild
My mechanic wanted 15-20 hours to convert everything over on to a fresh long block. At $80 per hour, plus any new parts etc. So...I bit the bullet and am doing it myself...LB was $1550 delivered with no core charge. Saving some bucks and it's actually been a good learning experience! Hope this helps...
grouper249
Re: 5.7 Rebuild
Our 96 5.7 MPI was rebuilt 3 years ago for $3400. Keep in mind this included manifolds, Alternator, oil pump & pan, flywheel and a few other things in addition to the "standard" rebuild. With that said i've learned quite a bit about rebuilds, the shop who performed the work did a heck of a job, second, there are many components that have gone bad simply due to time, ie. remote oil lines, cooling hoses etc that were not addressed during the rebuild. From a post mortem perspective, i would have replaced any component that is/was difficult to access once the motor is back in place. Hope this helps!
lunasea
Re: 5.7 Rebuild
a local mechanic offered 4 g to replace my motor with a new long block and im wondering if i should have taken the deal
Pete104
Re: 5.7 Rebuild
Depends! Saltwater or freshwater? Doing any transom work? Doing any drive work? Is all your "tin" in decent shape? How about the manifolds & risers?
They could probably get the rebuild itself done for 3500-4000. Plus labor
