Re: 5.7 OMC Flush kit
Ok,
Well, first of all, you'll need to get yourself a correct year OMC Service Manual. (not a Seloc or Clymer)
The manual is fairly specific on how to do stuff...
In general, If the drive is an unknown "quantity" and you don't know how long it's been since everything was "serviced",
You should carefully inspect the drive bellows, gimbal bearing, and if I got a drive used,
I would want to know if it would hold pressure & vacuum. (drive oil leaks)
You should also check and adjust the engine alignment since that's probably not been done in years.
Learn about how the ESA system operates and inspect your lower shift cable closely.
Read the following:
http://www.hastings.org/~stuart/cobra/
Also have a look at the DIY "Sticky" messages at the top of this (OMC) message forum for other maintenance "stuff".
My Current boat is an 87 Four Winns 211 Liberator that my brother bought new with an OMC 460 King Cobra. (About 6 years ago, I pulled it all out and replaced it with a 1997 Mercruiser 454/Bravo) I learned A lot doing that job!
There's a LOT of people here that have made most or all of the mistakes you can make working on one so don't be shy about asking questions!
It doesn't take a Rocket Scientist to work on these things. Just a little common sense and normal hand tools...............Do you homework though! Read that stuff above and get a manual! It'll help immensely in the long run! (there's even someone here that has some OMC manuals saved in digital form for the asking!)
Cheers,
Rick
