5.7 Mercruiser - ran low on gas, now won't start
JimJam63
First time boat owner. Bought 22' Larson Hampton this spring. Have had it on the water 4x, Started fine each time. Last outing ran gas low, less than 1/8 tank. Think may have sucked up bad fuel. Boat stalled on the water, haven't been able to start since. Turns over, sounds like it wants to start but won't. Seems to be getting fuel, can smell gas when trying to start, tried spraying starting fluid in carb with no luck. Things to check?
alldodge
Its a Merc 5.7 carb what?
Year, serial number would be great.
Pull the fuel filter and pour contents into some clear to see if you only see clean gas
Starting fluid does nothing, but if the plugs are soaked it may not hit
JimJam63
Thanks, yes carb'd will post serial number tonight don't have it on me. Boat is a '92, shows 480 hrs on the motor.
alldodge
You should have a TB-4 ignition and a mechanical block mounted fuel pump
thumpar
Do like stated and pour out what is in the fuel filter/separator into a clear jar. Let it sit and see if there is water in it. You could try running it from an external tank.
alldodge
Thanks for the S/N, says you should have a TB-4 module and the latest p/n is 805361T6 for a Bravo drive
JimJam63
Pulled fuel filter, it was clean. Replaced plugs. Put muffs on and started up after some attempts. Gas and milky sludge from the water ran for 5 - 10 min. Tried restarting wouldn't. Pulled dipstick and milky oil. So much for boating this summer. Head gaskets? When pulled plugs initially they were in poor shape but no signs of oil etc. This all happened last night, pulling plugs again today to take a look there.
Ayuh,..... Welcome Aboard,...... It's rarely ever a head gasket,.... Much more likely a cracked block, 'n heads,.....
TurtleTamer
Could be manifold(s)/riser(s). I was that lucky. Good luck, hoping for the best.
JimJam63
been reading forum posts. Came across one about running in trailer position which is what I did when I ran after putting in the plugs...the drive wasn't in gear but wasn't lowered. Seems weird that the boat ran fine the 3 times out previously then bad, assumed gas. Start/Run after plugs was first only time oil/gas showed up. Had checked dipstick when first sign of trouble and it was fine. Would a block just crack?
alldodge
Note in warm weather just sitting. It might have overheated a tad and blew a head gasket, maybe something else. Your first post said you ran low on gas, and this may not have done it, but if it ran lean for even a short time, it can damage something.
In any case you need to find where the water is coming from.
TurtleTamer
I'd pull the intake manifold and check for bad gaskets/cracked intake/block crack in the valley.
thumpar
Don’t pull anything before you do some basic dishes. Once you take things apart you can’t test. I would do a leak down and pressure test the water side.
BudL1te
Leaky risers from bad gaskets can cause water to enter the cylinders. This can cause engine to stop. As the water drains past the piston rings it enters the oil. I thought my head gasket blew because I found water in the oil as I was changing it to get it ready for the season. I remove the head, but the gasket was fine. Turns out the Riser gasket needs to be replaced every couple of years apparently. Had I known this, I would have likely taken the spark plug out of all of the cylinders, crank the engine over several times to get as much water out as possible, leave the spark plugs out to let the water evaporate off of the top of the Pistons, throw a few squirts of transmission fluid into each cylinder put fresh plugs in, change the Riser gaskets, change the oil, fire it up and let it run to burn any additional water out of the cylinder, change the oil again. Run it some more and check the oil. I suppose it depends on how New your engine is as to which route you want to go. The only other route, is to remove the heads, get the cylinder walls cleaned up, replace the head gaskets, the risers, the oil etcetera. That would be the proper route.
