My 5.7 motor's harmonic balancer seems to be installed incorrectly.
The timing mark does not line up with the timing adjustment guage. It's not even close.
Someone put a mark on it with a yellow paint marker to use for timing adjustment. Is this a problem? If its just a matter of removing and reinstalling correctly I may do it. I thought there would be a Key/Keyway setup on the crankshaft.
thanks.
thanks.
