5.7 liter dies when put in gear
summerwind1991
Thought I might not have correct prop(16 1/2 x 23")me out wanted to check WOT. 1997 Bravo II, should be 44-4800. Well it got to 5200,I quickly powered down. Now, where there had not been a problem prior, currently it will now stall when ever I put into gear. Not sure what happened, on the way to checking out proper prop.
waterdog85170
Re: 5.7 liter dies when put in gear
i dont think one is related to the other. but first, what kind of drive? model? year? if its a merc id blame lower shift cable.
summerwind1991
1997 merc 5.7 liter, bravo II 210 SHP. Gear ratio, 2.2/1 gear ratio.<br /><br />Yesterday, started put into gear seem OK, however I did not go above 2500rpm. Only change was that I replaced the two dead batteries. Would dead batteries cause engine to quit when put into gear or does alternator take over.
Anything is Possible......
summerwind1991
Thats interesting, going to take out for another test at higher speed. Thanks.
