Wheelman81
Thread starter- Joined
- Jun 1, 2018
- 6
Engine bogging and sometimes dies after running over 10 or 15 minutes at 3000 rpm . Engine will run fine all day long at low cruising rpms (under 3000). I have changed water separator and drained and refilled fuel tank and new plugs and wires oil change as well Also replaced flame arrestor. Not sure if this is fuel related or some kind of heat sensor is shutting the boat down due to over heating as i have no working temp gauge. I took to mechanic shop and the guy changed the water pump and after that did not work he was telling me it might be the exhaust manifolds or the thermostat. In my opinion he should have changed the thermostat before or with the water pump if he thought the water pump was the problem. So I read reviews on his shop and realized it was no longer owned by the same guy I had been dealing with for over 10 years so I am gonna have to travel a ways to a new mechanic. Any help would be greatly appreciated.
