H2recovery
Thread starter- Joined
- Aug 15, 2010
- 6
OK, I have re sized this so that it is easier to understand. I am on my 3rd engine in the past 4 years. I keep loosing them do to them over heating too many times. Each time they have over heated I have had to change the oil because of the lose of oil pressure and the cooking of the oil from the severe heat.The over heating mostly happens at wide open throttle for 30 seconds the temp will shoot up to 200-220 and suddenly drop to zero and that's when she is running hot. O degrees and you hear the engine pining.
I just put in the 3rd engine on Thursday and took the boat out on the water Friday and Saturday. Friday she ran perfect all day long. I put about 10 hours of run time on the fresh engine. Saturday we took it out again and drove it 13 miles down the lake and she was fine. I decided to take it up to 3/4 throttle and the over heating scenario happened again 220 and then 0. I shut the engine off and you could just hear the engine crackling and bubbling from the heat. The engine got so hot that it melted the plastic elbow shut for the crankcase vents.
Each engine has a new thermostat and new impeller and new engine circulation pump for a serpentine belt. Yes the belt is routed the same way as designed.All three engines had different intake manifolds. The only things that remain the same are the hoses which I have verified that they are clear of blockage and the heat exchanger for the power steering which is clear too. I have the original exhaust manifolds on the engine and the original rises.I currently have the rises off the engine and you can see they are not rusty nor do I see any blockage
Can anyone tell me by looking at the photo of the thermostat housing, is the plastic sleeve installed correctly?I was missing this on the first engine from the previous owner replacing the t stat.
One other thing I did notice when the second engine went was when I split the outdrive to inspect the impeller I noticed the tube coming out of the upper housing of the impeller had a dimple in it and it did not line up correctly to the housing when reinstalling the drive. I had to pull it down to make contact with the o rings inside the housing. Could it be possible that the dimple is causing the pipe to push out of the pump and fill the cavity up in the out drive and starving the engine for water?
Mike
Mike
