garbageguy
- May 8, 2012
- 1,633
I have not been able to locate a model or serial number on the block. It's a Volvo 5.7 GL in a 1998 24 ft Wellcraft 240se cruiser with Volvo outdrive. The engine is black (charcoal?).
When cold starting, it takes a couple times to stay running, not a big issue (I think). When it fires and catches, there's a very brief whine but runs smooth. After temp comes up, I reduce throttle and it will idle fine at about 650. Underway, it runs fine until hard throttle-up and when rpms get to about 3100, it will bog. Let off throttle and can cruise off-plane OK all day. With less load in boat (just me), can get it on plane by coaxing throttle up, then down, then up a bit. It will run on plane at about 3100 rpm, but if try more throttle it will bog. Thoughts?
