5 1/2 hp shift lever
reelfishin
Might anyone know if the shift lever off of a 1961 Evinrude 5 1/2 HP will fit on a 1964 Johnson 5 1/2 HP CD21?
(The old one on my good running Johnson has been gone for years, I've been shifting it with permanently attached vise grips for about 20 years now, I have the chance to buy a seized '61 Evinrude that has a good shaft for cheap).
F_R
Re: 5 1/2 hp shift lever
Probably the same, EXCEPT for the shape. There is a chance it won't clear the cowling. If it is the same, it will have the same part number. I haven't looked it up.
bktheking
The 64 is angled and shorter and the 61 is straight and longer, 2 different part numbers, doubt it will work.
reelfishin
That's pretty much what I needed to know, I don't have enough of the old one on the 64 to tell what it looked like. I'm sort of guessing though that it looked pretty much like the one on my 1967 6hp Evinrude. All I have is a steel shaft sticking out with a stump of cast aluminum on the end. I filed it down a bit so the vise grips would hold better, but the last owner was using it the same way I guess.
reelfishin
Good links, thanks!
I'll keep my eyes peeled for a junk 6 hp then, chances are I'll be able to pick up a whole parts motor for $10 or $20 sooner of later. I may even know some one that has one.
It looks like the 64 5.5 was more like the later 6hp motors than the older 5.5 motors?
ezeke
The 1965 6HP is a lot like the 1964 5.5HP. After that they start making changes to the 6 that are not so compatible with the 1964 5.5.
reelfishin
I went digging around at a local junk yard where I've found a few motors before, came up with a 1967 6702S parts motor for $30. It was supposed to be seized up, the guys had set it aside at the junk yard but said it was seized. I was about to just tear it down for parts but something made me pull the plugs out and see what was up, what I found was that it had one plug installed with about a 1" reach, locking the piston dead against the plug. I didn't see any damage to the piston through the plug hole so I shot it with some motor oil, worked the engine back and forth, lubed up all the linkage and shot the carb with some fuel mix. I got only one cylinder to fire at first but I then pulled the flywheel, cleaned up the points and got both to fire, it fired right up on a few shots of fuel mix so I hooked up a fuel tank and hung it in a barrel of water. To my surprise it runs great, even pumps water. The prop needs some attention but the rest of the thing is fine. I checked the compression afterward and got 112 on top, and 110 on the bottom. What surprised me the most is that I never had to touch the carb. The motor is in really nice shape, especially for being something that someone most likely sold for scrap. The cover, is intact, no damage, the paint is dull but not scratched up. There's also no salt corrosion, which is rare for around here.
So much for finding a parts motor though. This thing runs as good as the 5.5 hp I needed the shift lever for. There's no way I could part this out now, it may just end up on the boat in place of the 5.5hp.
I still want to fix the 5.5 though.
What was different between the 5.5 and the 6 HP? They look like the same basic motor. Is the 6 the same displacement size as the 5.5? I see the carb and recoil starter are different, but that's only due to the low profile set up on the 6hp.
