I have a 5.0LX (SN#OF27759) its around a 94 model and has a quadrajunk 4 barrel carb on it and it is surging at idle. It is going from about 800 to 1000 rpms. You can see it on the tach, here it and feel it in when Idling through the marina. I recently bought this boat and have had to go through it from top to bottom (thanks to these forums for guidance) and for the first few outtings it ran fine, Although I have not really pounded on it too much. I have drained all fuel after purchasing the boat as it was a couple years old. Change fuel lines, filters(yes I got the one in the carb), plugs, distributor cap, wires and rotor, oil change, drained lower unit and reservoir of drive lube and replace and replaced the impeller. I am thinking the only think left to change that could cause the surging is rebuilding the carb, but wanted to bounce it off you guys before I tore into it.
Thanks
Thanks
